Well, the saw runs, idles, and cuts wood, so I should be elated, but this damn thing kicked my A$$ today!
Really wanted to finish it up so I could cut with it tomorrow. Had some house chores to do, and some work stuff, then I got to it. Was going OK till I got to the chain brake. I hate chain brakes anyway, one of the most frustrating things to do, but I thought I had it and I just could not get that chain brake to go on, looked like the linkage was lined up, etc, but it just would not go. Damn if they did not undersize the hole on the inside of the chain brake lever (the outside was correct). You know how much time I wasted trying to get that damn thing to go on, until I figured out the hole was too small???
So, I get the chain brake done, and I check out the carb. Lo pin is very stiff, but everything else seems fine, choke and throttle seem to work perfectly. Got the saw to pop + run, but then it would not idle. So I shut it down, make some adjustments, and it won't start!!! Tear it down, and the choke is sticking shut.
No time to mess with it, I pull the carb from kit #2 and check it out. Again, everything seems fine except the Lo screw is stiff. Put the new carb on, and the saw still won't start. Pull it down, and the choke on this one is also sticking shut!!! Grab an old dirty carb from on of my broken 046/460s. No idea if it is good or not. Put it on, it won't start. Check it out, the choke will not go on!!!
Play with it till I get the choke to go on, start the saw, adjust the carb, SHE IDLES, I was so happy, was worried I had a bad seal! Now I just have to play with it tomorrow morning and get the choke to work right every time! Oh, and then the decomp button looses it's cap (I'm making a new one, don't want the saw to eat it).
So, even with .030 squish compression is as much as I would want, the combustion chambers on these cylinders is tight, and the exhaust is a bit low. Only made two cuts with it, in 18" Ash, felt good, but I hope it improves with breakin and some tuning. I likely have it fat. But she runs clean, right from the start!
Pics: 1) Inside Chain Brake hole is too small, 2) Do hickey that came with the crank bushing is for the upper vib mount, 3) the Chain Brake hardware is a rubber bushing and thin metal tube, 4) All together and ready to cut wood, just got to put the inner dog on it.
