I'm sure it'll be fine I haven't had one yet that was too bad with a decomp.I hear you Mason. It is not the squish # that scares me, it is the tiny combustion chamber in conjunction with that squish #.
Hey, just going to give it a try and see what happens!
How wide is the actual squish band?
You can be off by 5mm on the Conrod and it will Still be close. Just eyeball it with calipers or a mm rulerI was after Stihl conrod sizes. Guess I should have said ..so. Doh..
What kind of compression #’s do these things have?
Bring it to top dead center then drop it. My decomp is plugged on my chinese saw. Timing advance hurts if you don't bring it up first.I know there can be lots of other factors, but many "in the know" called that the intake was too high on jug # 1 for performance, and I think that is the largest difference.
I'm using Caber rings, and it is very good. Jug # 1 has .030 squish, and it feels like pulling the Cross P+C 660s, and Jug # 2 has .018 squish and I find myself using the decomp button more often than not. I already broke the pull cord once by not using it.
For all the faults these jugs may have, the combustion chambers are beautiful, look just like a Mahle D jug!
That's when it'll happen. Top dead then drop start. WorksThe cord did not break when I was first starting to pull it. The saw had popped, and I gave it a good pull, and near the end of the pull the saw fired and I had a handle in my hand. Cord broke right at the handle (a knot and about 1" of rope).
I like how it runs, but it is my toughest saw to pull over.
I think your on the right track I just did the opposite on a farmertec ms660 cylinder I had to raise the intake on it but that's about the norm.Timing #s
OK, here are the timing #s I came up with (all w/o base gasket):
First the New West Big Bore:
Sqish .030 Ex 103.5 Tr 122 In 64
Now the Huztl 440:
Squish .058 Ex 101.5 Tr 124 In 71.5
I'm disappointed with the Squish # on the 440 and the Intake # on the Big Bore.
Being as the Big Bore cylinder has a very tight combustion chamber, I can live with the .030 squish, but I think I need to try my hand at grinding and lower that intake to the mid 70s, then it should be good to go.
Thoughts/Comments both welcome and appreciated. I've never grinded on a jug before, but I think I can get to the intake with my Electric Sharpener with the Diamond Stone. By comparing it with my D jug, I know about where to bring it.
Pick that cylinder up and hold it while your grinding. You scared of it?I had to go to HF the other day, and they had these Dremel style tools (corded) on sale for $9.99, so I couldn't resist. These tools are not for the pro, but if you just want to do a little here + there, they are not bad. It spins at 16,000 (kinda like a chainsaw)!. The biggest problem I have noted is it is difficult to install your cutter w/o wobble, and when you do get it straight, tighten the damn thing with some channel locks or it will not stay straight for long. Looking back, I should have just bought 2, one for a carbide tool and one for a diamond ball, cause switching cutters is a PITA. Also, as you use it, keep the pressure light, or your cutters will wobble right away.
Other than that, the tool is very small an nimble and seems to work well. The uppers in these Big Bore jugs end prematurely, so I figured I would kill 2 birds with one stone and install some bridge ports that would increase transfer flow and relocate the terminus of the upper at the same time.
I wish the "before" pic was clearer, but I don't think the after pic looks too bad considering this was my fist attempt with one of these things. (This is Big Bore jug #3). If this helps performance, the other jugs will just have to come off!!! I used a carbide cutter first, then a diamond ball.
