- 3:02 PM
- Jan 24, 2018
- Extreme Southeast CA
It's more about the handling and operator/saw mechanics. With the saw weight pushing down bucking, you'd think the saw would get stuck more, but it's the opposite. It's easier to modulate the feed rate. Get it wound up and let it rip all the way through. The weight helps feed the saw and not much dogging is required (with an aggressive chain).Could youexplain why?
To me a cross-cut is a cross-cut. There's more silicon near the base (the mineral that helps give trees strength) and depending on stresses the tree endured the grain may be knotted up, but the cut is the same (to me) other than having to support the saw properly and watch for unexpected pinching.
Noodling/milling (rip cutting) is of course different as the cutters are removing material in the direction of the grain instead of across it and doing so is more "peeling" the wood than "severing" the wood.
When felling, there is more stopping and starting(this is the bulk of the issue), awkward positions (dogging in too hard), and chips do no clean out as well either. No weight of the saw to help feed, so one must dog in, often awkwardly and may stall the clutch. Also, with too much hook, one must pull the chain away from the wood before letting off the throttle, or the chain will get stuck and not want to start up again.
Not the best example, but IIRC, this chain was a bit aggressive. Note a little stalling sound when felling but cuts like butter bucking.
