- 3:07 PM
- Dec 3, 2015
- Banner Springs Tennessee
Any updates on this?
Still waiting on parts. Another member here is kind enough to look for parts in his stuff and off of the web.
He's been a bit busy.
I have been busy with stuff as well.
This saw has priority over my personal saw projects. (exception is simple stuff on other saws)
Worked on the saw a bit today. Got the cylinder about 98% free of aluminum transfer. Did it by hand with some 240 grit and 600 grit. Worked well and took about 15 minutes or so to get tons of that transfer off of the chrome plating. Have a tiny bit left, will work on that some more after supper.
Installed the piston onto the connecting rod, with oil on the bearing and wrist pin. Aftermarket wrist pin was a barely perceptible difference in oz compared to OEM, so I used it. It was almost exactly 1 oz, while the OEM was just a fuzz less.
As for circlips, could not get the clip out of the unnotched side of the OEM piston, so I used the aftermarket clips.
Cylinder is not on the saw yet, so if you have had these clips be a problem, let me know sometime tonight.
I checked the springiness and return to form tendencies of the clips and it looks good from my moderately trained eye.
They do have these ears that make installing them real easy. Have read elsewhere that some guys clip those ears off to keep the clip from coming out? Necessary or just an old precaution?
Will have some pictures of what has been done either tonight or tomorrow.
As for this saw, I may or may not be the one finishing it. I have surgeries coming up soon, and since they are on my eyes, I have to take it real easy for quite a while. I still have to work next week as well.
Long story short, went to eye doctor, she found questionable problems in my eyes, sent me to a specialist, and we found out both eyes have lattice and both eyes also have the beginnings of retinal detachment. As my brother had the same problems, I figured this would also apply to me. I was right.
Still waiting on some parts, but I will get as much done as possible. If necessary, I will send the saw to someone that can get it done sooner, if that is what the @fossil wants.
Will not be able to tear the saw all the way down for a good cleaning, it will be a mission of getting it clean enough and put back together to run. New fuel and impulse lines will be installed, as well as a carb kit.
Otherwise, it will have to wait to be finished, about 2 months, maybe longer.
Take your time Kyle. No rush. I understand the eye problem deal as I have glaucoma. Get well first. I certainly appreciate your efforts and I can clean the saw up or even finish it if you like.
New fuel line is installed, new impulse line is installed. New fuel filter is installed as well. Carb kit on the way, should be here tomorrow.
Is it okay to use tygon for impulse lines? I know with fuel lines, it doesn't seem to last. If it isn't okay to use it, please let me know and I will find a piece of rubber line to use instead. This is the Oregon stuff, at least that is what the box says on it.
Is there a good way to clean up around the seals without using brake kleen or carb clean?
I know those are hard on rubber, and don't want to ruin a seal that may end up being okay until it cracked from having pure hydrocarbons spewed onto it.
Should I just use a toothbrush and warm soapy water?
Wd40 cleans very well, and won't hurt the seals. Tygon is not a great idea for impulse line.
Found a clutch cover, it fits. No chain brake though. So @fossil be careful with this saw.
Now to find those wrap handle screws. Socket cap 1/4"-10 pitch .875" long. Need four of them.
Still recovering at this time. Everything is blurry. Just able to barely see what I am typing.
