WI_Hedgehog
- 1:59 AM
- Sep 8, 2023
- Milwaukee, Wisconsin, U.S.A.
If there's no spark a shorter path could be grounded to see if the coil is weak, I suppose.How can it help the spark start and jump the large gap, unless it is grounded? If grounded, why would the spark jump the wider gap and not just the short gap of the third post?
There's this "thing" where a mechanic puts the spark plug in the plug boot and clips a test lead between the plug body and engine ground then fires the engine...
...if it doesn't spark the plug gets replaced and re-tried.
There's no guarantee the replacement plug is good and tightening the gap to test the coil isn't as easy as on the ECHO spark tester, but the test lead doesn't cost $85...unless it's from Snap-on.
