amiga
New OPE Member
- 3:45 PM
- Jun 24, 2022
- Whiting, Maine
I have an old McCulloch MS1635 chainsaw. This has no points. I lost spark. I removed ground wire from coil and tested with spark tester and have no spark. I cleaned magnet surfaces on flywheel and set gap from flywheel to coil. I sanded clean the surfaces between coil mounts and coil housing. Magnets are strong and will hold a screwdriver. I got a coil off ebay that was supposed to be new, but looked like it had been thru a war. It didn't work. I sent it back and found a new coil on Amazon. This one looked like a new coil. Still no spark. I ohmed it out and got 2.8k from spar plug terminal to coil housing and same from spark plug terminal to spade terminal. I got 3.8 form spade to housing. I am unable to find any specs to tell me if this is normal readings. When i test for spark I plugged in spark tester and had a jumper wire from spark plug to ground and a wire from ground to coil housing. Anyone know if these reading are normal or any ideas on what I missed. Thank you for your time.
