chy_farm
- 2:20 AM
- Jul 3, 2017
- Yokohama, JAPAN
Absolutely beautiful workNow on the way to enjoy making a pipe for old McCulloch, e.g. 740 for the first challenge.
Still she has a lot to be altered for better efficiency, e.g. the pipe length is a little too long for higher velocity of rotation.
some more will come later.
Chy
Thanks, but your question somewhat embarrasses me, since painting is one of the weak points of my saw thing, lol.Looks great!
What kind of paint or powder are you using on the pipe? And does it hold up?
Thank you T.Roller, your words are a little to much for my work, lol. Will do the best to be able to mach the evaluation you gave me.Absolutely beautiful work
My brother tried painting a pipe with hi temp engine block paint. Rated to 400 degrees, didn't last long at all before it was burnt and discoloredThanks, but your question somewhat embarrasses me, since painting is one of the weak points of my saw thing, lol.
Well I went to a box store in the vicinity and got a couple of color paint can for outdoor use, it says Silicone Lacquer on the label.
The worst thing to my painting was one on magnesium, pipes are made from steel so it seems the paints hold up.
Chy
What's going on DeetsMy brother tried painting a pipe with hi temp engine block paint. Rated to 400 degrees, didn't last long at all before it was burnt and discolored
You do great work sir. Welcome to the siteThank you T.Roller, your words are a little to much for my work, lol. Will do the best to be able to mach the evaluation you gave me.
Chy
Hi my friend, I found not a few McCulloch enthusiasts here many thanks.Good work chy
Nice mcculloch.
I'm a mcculloch loverHi my friend, I found not a few McCulloch enthusiasts here many thanks.
Chy
Glad to have a new friend T.Roller, thanks.I'm a mcculloch lover
Hahaha, I do not hope that StumpShot! thanks.You mean to tell me there are people that don't like McCulloch's?
Hello Randy, first of all I should like to identify if you are the RandyMac who;uu Umm... You don't "use" CAD my friend, you, Have "CAD" BAD1!
Nice work and glad to see an American Muscle saw alive and well living across the pond in the ring of fire.
Your fabrication skills and inginuity is what stands out the most to the builder guys here. Anybody can make stuff pretty, but run and look sick, not.
RandyMac Sawer Saw
@Lee H check this out
Cool saws you have there.
Lol, you have a couple of good eye sight StumpShot! but you may find additional "O" just above the line, which I occasionally put on there! lol. These are cut-out letters from a sheet of paper, found this "O" beeing left of the table after I put the last letters "ch" for the line. Was a funny moment to me with a lot of astonishment, was not able to close my jew!! Thanks,Nice job pounding out that flywheel cover there Chy. Hate to be the one to tell you this, but it appears your lettering on your pipe is missing an "O" in the word"McCulloch", if I'm seeing that correctly. Might need a touch up. Otherwise keep up the great work.
