O46 timing advance
lehman live edge slab
Live Action
9:46 AM
Mn
Is it worth advancing the timing on my friends 046 after I get the new cylinder and polish the ports? Poly flywheel if it makes a difference.
10:46 AM
I did a dp muff cover on my brother's MS460, and it did not seem to make much difference. Then I advanced the timing (.020 off the key) and it really came alive. It is also running a HD-2 air filter.
I would definitely recommend a timing advance on any modified (including muff mod) 046/460.
Just like with the old cars, if you let more air in, and more air out (improve the flow) a timing advance usually works well in conjunction with those mods.
10:46 AM
What type of mill do you use to slab?
Awesome cuts there.
Live Action
9:46 AM
Mn
Awesome cuts there.
I have 3 grandberg mills, 30",48" and a 72" double ended. Powered with either my 075 or 090. Only thing I need now is a 50"+ large mount stihl bar so I don't have to drag my 72" as much. Not that I take it out lots but most times my middle mill would do if I had longer bar. Almost 14' of chain on large one.
Live Action
9:46 AM
Mn
Forgot to ask but I suppose I need another flywheel puller. I have the double sided one for most of the older aluminum flywheel saws and the one for small saws like the 200t for working on my friends climbing saws
10:46 AM
Awesome. Thanks
Deets066
AKA Deetsey
10:46 AM
If you have the double sided one that should work
10:46 AM
The 044, 440, 046, 460 all use the same one. The 066/660 is larger.
For anyone who does not have one, I think HL Supply currently has em on sale for under $10!!! I paid more than twice that, but it was well worth it.
If memory serves me right, it does not work on the 024, 029 or 362.
10:46 AM
What are we talking about? Flywheel puller?
10:46 AM
LOL. Thread got a bit sidetracked.
