PDX Man
OPE Member
- 6:59 PM
- Jun 25, 2017
- Portland OR
I don't think you have done any damage starting with wot,
It's when your trying to work out what's wrong, it's 1 or another equation that needs to be eliminated.
An engine needs spark, air, fuel, compression
I still think It's fuel starvation, get a spray bottle and spray fuel in the carb while it's running, and try and open the throttle.
This way your providing the fuel and opening the throttle provides the air. And you have a spark because it starts and runs a bit.
It may run rough, but as soon as you stop spraying fuel, if it dies then it's fuel starvation.
If you watched the vids I linked, the 1st one shows him dumping x amount of fuel in the air intake. This is what I would do to get the engine started, which saves pulling the cord and saves my arm, by spraying you can see/hear every time you spray the engine should Rev up. If it don't then fuel is not the problem.
Anyhow, it's up to you to try, and if it don't work it must be something other than fuel.
And/or you can do it with the other AM carb,
If you can keep it running by providing the fuel from a spray bottle , that indicates not enought fuel from the carb,
The only othe thing I can say is change the spark plug for a known working one or test the plug in another machine,
Cheers
I don't think you linked the video you think you did. They both do some basic diagnostics and then mainly focus on a cursory cleaning of the carb. I didn't see any dumping of fuel in the air intake.
