Fish
- 2:14 AM
- Jan 18, 2016
- Manton Ky.
Have you ever checked the flywheel key?
Have you even read any of the posts?well theres yer problem...the valves weren't even in the engine...howd all you guys miss that?
$12 carbonationator kit woulda saved this from becoming a $ .03 scrap pile, ohh well
I have and you make senseHave you even read any of the posts?
yup...look back and see who mentioned a look at a highly unlikely sheared key...I have and you make sense
His posts not do much
that wasn't a constant symptom...it only happened when he was dumping gas down the intake!So flaming backfire is a common carb problem eh?
BTW, a common practice of diagnosing small engine problems is putting a dribble or spray shot of fuel directly in the intake {not a pour}, and a flaming backfire is not something that a problem carb would cause, but would be a clue leading in other directions.
A sheared flywheel key is still another open possibility,
what are your suggestions?
Please, give a suggestion to ADD to the thread, not say something nasty and incoherent,
and put up stupid moving smileys...
A sheared flywheel pin would mean the flywheel spins on the shaft, right? It doesn't by hand, anyway, I can't turn the flywheel on the shaft. Or could it mean that it is stuck on the shaft at the wrong position? If I need to check that, what would I need to remove? I couldn't find any videos on youtube covering this.
So now the carb is clean, and it does not seem'do to have resolved the problem. Does it still tick over a bit with the throttle closed, have you open the fuel mixture screw out 1.5/2 turns.
I don't think its the flywheel key unless you taken the flywheel off and not put it on wrong. But it could be the key ?, it's an elimination process, Is there any rusty deposits in the flywheel magnets
But I'm now thinking it's the coil. Do you get a good spark on the spark plug,
Do you know anyone with a simular engine where you can swap/try your coil. In there engine.
And watch this
This is worth a read,
https://www.smokstak.com/forum/showthread.php?t=72156
They go over simular topics
It says could be spark screen, if you have one,
It says try running with the choke on a a little bit, as this increases the fuel air ratio
Everything I see/read says fuel, carb clean first, then spark/coil timing.
a weak valve spring with worn valve stems or guides will have the valve not seat SQ and would cause a backfire and would cause a stalling problem as back presser in to the intake man. I saw the pics of the valves the intake is seating closer to the outer margin then I would like to see it. the exh valve looks to have some carbon on the valve face that would cause popping from the exh. the OP's vid valve 2 at the 8sec mark after he grabs his phone I did hear some popping if some one would listen to the vid and tell what you may hear? I was going to say to put a compression gauge wipe on in the spark plug hole and hook up a compressor and listen for leaks at the intake and exh but I was to late threads gone 120 psi will have more leakage then water.
