- 5:02 AM
- Feb 5, 2016
- grafton wv
he said it passes vac and pressure test
how good is theese tygons versus to oems , i hear many use them ?I was milling with my 7900 and it started running weird. I shut it down and found the tygon impulse line melted off. It ran, but I knew something wasn't right
tank vent?
Did you vac test through the impulse hose?
How's your coil? Do you have another coil you could try? New spark plug?
Not worth a sh!t. It melted off. I bought some echo line from fordf150. Flawlesshow good is theese tygons versus to oems , i hear many use them ?
ah, that makes grammatical senseall together .................include fuel tank, throtle cables, fuel lines, and filters now understand ?
when just the time you hit the throtle ??? just because you say that the saw pass the pressure-vaccum tests and start - idling very goodImpulse line off the nipple.
Took the tank vent apart
