Bob95065
- 10:10 AM
- Nov 7, 2016
- Felton, CA
I am working on an early 029 that has ben a nightmare rebuild. I have it back together and it has an erratic idle. This was confusing because it passed a pressure/vacuum test. I had it running and sprayed some brake cleaner around the carburetor and the engine died. This makes sense because the carb was replaced with a block off plate for the test..
How do you test a carburetor? I did rebuild it. I want to determine if the carburetor is the problem or the OEM intake boot I put on it before I buy another boot.
Thanks.
Bob
Thanks.
Bob
