I took two nearly identical Asian 660s (w/Cross P+C) (I called them Asian Twins because you could not measure the difference in the port timing) and one I opened up the muff more than the other. The one with the open muff sounded stronger, had better throttle response, etc, but died in the cut (I was cutting a large very dead Chestnut [Rock] Oak log). So I changed the muffler to the same as the first saw and then I could lean on it just like the other one. To be honest, I thought the one with the open muffler sounded better and would be stronger, the results surprised me. However, in the wood it was very obvious I could not lean on it like the other one.
It all depends on the port timing, shape, etc, etc. I have learned there is no one hard and fast rule, each saw is different.
I know there are a ton of variables, but when the same person tests the same saw model, with the same B+C in the same wood, you can judge how long it takes to make a cut and how much you can lean on it.
Several other 660s have responded just the opposite for me. It really just depends on the saw.
The Asian Twins are the two strongest running Asian saws I built (w/o and port work), and were stronger than a lot of saws with port work. I lament that I had pre-sold both of them before I built them, but both owners are very happy with them.
