RU NUTZ TOO
- 3:55 PM
- Jan 5, 2016
- canuckistan
I understand how a larger CFM carb can help a saw, but on my 044s and 046s, if they already get enough fuel, why would I want to drill anything out???
Would be different if I could increase CFMs.
this is where the confusion comes in mike. people think if they increase the flow of the low it will improve torque when a saw is loaded hard. not the case at all. the low speed will flow something with the throttle open but almost nothing. when the nozzle is pulling from the chamber it puts a negative pressure in the chamber which pull the diaphragm down to open needle and refill the chamber. this negative pressure pretty well holds all fuel from the low speed chamber. some will flow but so little it doesn't amount the nothing. alot of zama's do benefit from this mod that brewz describes though which is why i figured he was talking to a zama guy.
