- 9:28 PM
- Dec 30, 2015
- Brewster, NY
Love my 261 CM Ver II, with MMWS! Very versatile light weight saw.
I don't think there is a "rich mode." The way I understand is the control module just monitors the rpm's and adjust accordingly. I could be wrong. It's happened before.Different (reset procedure) than what I had learned. On the older M Tronic, 1) Start position for 90 sec, shut down, 2) Run 90 sec at idle, shut down, 3) restart saw and put it in some big wood.
The problem is when the saw is run low on fuel for too long, it goes into rich mode (to protect from an air leak) and the saw will not start (normally) or idle, and you can not reset it yourself. Some dealers know how to do a reset after this happens. You can often start the saw if someone holds the throttle open while you pull the cord. The saw will not idle, but if you run about 6 tanks of fuel through it, it will eventually correct itself. It is a real PITA, but it works.
I'm not sure what they call it, but I have experienced it, and heard of others who have also. I know M Tronic is designed to protect a saw against air leaks, so I presume this is what is triggered when you run it too much low on fuel. The saw will not start, unless you put it on Run (not Start) and hold the trigger wide open. More annoyingly, the saw will not idle, you have to be active with the trigger for about 6 tanks to bring it back to life. It has actually happened to both my 362 and my 261, but when it happened to my 362 I did not figure out why it did it.
With the 261, I let a tree guy (climber) use the saw. He was loving it, but then it ran low on fuel. He kept insisting it still had fuel (not wanting to lower the saw) and tried starting it about 6 times, where it would just fire and then die. After that it was Hel*! Luckily, both saws are back to normal now, w/o any parts changed, and I like them. I just stay on top of them not running out of fuel.
It is a trade off I'm willing to accept for a saw that tunes itself for different temps, humidity and altitude. They are a pleasure to use.
Dan the legend sent me a genuine wrap handle for the 462 from Greece to Australia. So sweet! Thanks mate!!
View attachment 158430 View attachment 158431 View attachment 158432
Alex how much did Stihl sting you for the filterHey I went to get a spare air filter for the 462 here in Australia... these are the latest apparently.
Stihl Rep said that the only reason it's white now is that they had a lot of people not realising how dirty the black filters actually were and that resulted in starting issues with some saws. The white filters will make you want to clean them more often.
Is there anything @AlfA01 (Dan) can’t getDan the legend sent me a genuine wrap handle for the 462 from Greece to Australia. So sweet! Thanks mate!!
Wow, six tanks of misery just to get a saw to idle again? No thanks. Mine would be tossed in a ditch, or sold off on CL, long before then.
