hairybaby72
New OPE Member
Good day gentlemen, first I would like to say hi and thanks for any help I am about to receive. I have a Mcculloch ms1838av . I picked this up from a friend who said it was not running . It's a very clean saw and doesn't have much use on it. I initially tries to start it and no success. Fuel lines were shot. I replaced all fuel lines gave it a pump and she actually started after some pulls. It would stay running as long as the choke was closed but would take of screaming if you open the choke. At that point I was thinking it is pulling air from somewhere. So i pulled the carb off cleaned it and threw a gasket under it. Still same issue. So I start it again and shoot some carb cleaner around the carb gasket and what I am assuming is the crankcase gasket under the plate that the carb sits on. No response from the crankcase gasket but a small reaction from the carb gasket. Now I'm scratching my head. So I further disassembled the saw and took a peak at the crank seal. It's in one piece and seems to be in relatively good condition. So I have pulled the carb off countless times just to make sure I'm not missing something. I reassemble and now it will start and blubber and maybe stay running if the choke is on. I work on larger engines so i am not highly knowledgeable on saws and I have never seen a carb make a saw scream like it was. Do you think it may have been the carb the whole time causing it to scream and now just blubber? Thanks.
