Lightning Performance
- 9:19 AM
- Jan 26, 2016
- East of Philly
If it works it works.I've seen mixed reviews on it. I figure one 60DL loop to test is worth it. If it works out then I'll make the 84DL loops the same. I'm thinking about offering mobile sawyer services starting at $.45/BF for softwoods and a bit higher for hardwoods. We will see how much faster this new 3/8 LP rips after my spinner and breaker get here.
Seen many people running full chisel full comp chain that complain about slow cuts. They need to learn what a sharp chain is if your semi chisel or chipper chain cuts faster than full chisel anything.
If your going to test chain on the mill in softwood go big and go aggressive with a big power head. If you go with a tiny power head just cut yourself some hyperskip. Finding the right amount of cutters you can pull is a game... maybe a game of attrition when it comes to underpowered chainsaw mills. The commercial portable alaskan or Logosol type mills are mostly overpowered cutting most logs most times.
I found working over the saw itself to pull down low goes a long way in picking up speed and using a more aggressive cutter if you can pull it. Then you have to clear the chip without jamming it which requires some rpms well above where it feels like bogging is occurring. More cutter tooth face angle tends to take less power away to a certain point. It all depends on how many cutters and of what type you have in the wood. Testing chains with less is sometimes more. Worry about the quality second is my general rule. 10/10/60 cuts smooth and feeds nicely, leaves a nice finish but is painfully sloooow! on chain of any cutter type.
