- 2:35 PM
- Jan 12, 2016
- Iowa City
Simple hot/neutral theory here!
The ones that tickle are hot?
It can be tricky to deal with at times Dan...I’ve seen some real messes with older homes that were wired many decades ago.Simple for us that know it Jason!!!
You are correct. NEC code book is nation wide but inspector trumps the book everytime.Long and short of it in the OPs question is in the older days, electricians used to feed or send power directly to the light, then send power from the light back down to the switch on a 2 wire.
Nowadays, it is much better to feed or send power to the switch and a switchleg up to the light. Much easier and safer. It is also much neater in the boxes with less wires.
As far as I knew, the electrical codes are national standard, not individual by states.
Absolutely Dave.
AND, each inspector has their own personal favorite things they like to see BEFORE they sign off on the inspection too. Even in the small state of RI. You can wire to code, then they ask you to change it to suit their preferred way. LOL
Go figure.
Very true. Every light needs a true neutral. I think its easier to wire it the way I described.
Most every electrician I know feeds switches and switch-legs up to light.
When feeds were sent directly to lights, they bugged off the box for every outlet. Kind of the old way of doing things.
But your right. Nothing illegal doing it either way.
Have you experienced different inspectors having their own "preferred" ways of doing things? They tell you right away, the way you wired this is true to code, but I prefer it done this way? Seems like every city or town inspector have their own preferences. Lol
Gotta keep notes on what they prefer. WTF
You guys type faster than I. Lol. I am always a post or 2 behind.
We just cave in and give them what they want. Boss doesn't want any issues.
Actually they can. Look it up. They have the final say and can trump anything in the code book.Actually they can’t. But they try to. I challenge them.
If they want to enforce something not in the adopted code, it needs to be a written town policy. How can they make a contractor change work done to code and lose money, when they were not informed of a policy. If they don’t like it we go to the state inspector.
I’m not a dick about it, cuz I need to work with these inspectors over and over, but don’t step on me...
We try to get every inspector to do a walk through at onset and go over everything with them. Ask them if they require anything special beyond the normal code requirements. Then there is no surprises at the end.
I hear you about challenging them Dan. Sometimes you can win the battle but lose the war in the end. They play games, hold up final clearances and cause problems. Much easier to just play the game and let the inspectors feel that they are the boss.
It's actually written in the code book. When I get to the car this evening I'll let you know exactly where.
