Rich Fife
Sally slap my ass
- 6:18 AM
- Mar 4, 2023
- Central New York
Very nice work! I've never worked on a 2 series...
Nice Job pal. I never had that flywheel issue.
People talk about the 046 jugs being the most varied. The 262 probably has the most jug variations I have ever seen. Best one ever was the Mahle non-decomp, not the KS, in terms of transfer tunnels.
One lesson I learned, aside from the dozens of lessons that I’ve learned from you…….. don’t cut into the magnet(s) when trimming down that flywheel. Guaranteed you will know it when/if you do
I like Threebond for this. Actually just pried the oil hose out of an 044 that rebuilt three years ago and it was stuck in there like shít to a blanket.Tell me about Threebond... Would it seal the leaking oil hoses on 3 series Huskies?
So you've been to Johnny Depp's?I like Threebond for this. Actually just pried the oil hose out of an 044 that rebuilt three years ago and it was stuck in there like shít to a blanket.
Oh yeah we go way back...So you've been to Johnny Depp's?
It’s a lot of variation for a Husqvarna. So far I’ve heard of 4 different cylinders for it.
But there was probably more than 4 different cylinders of the 066 before it became the 660.
Yep that Right Stuff is awesome I use it on diff covers. It takes a lot of prying to get it loose. Never tried Threebond on case halves but I've used yamabond and hondabond, always had good results with those. I suspect those three are all similar if not the same.Threebond is ok but there is better sealing stuff. I tried to use threebond for sealing the case 1/2’s of my ktm 450 and it failed twice. OEM calls for a loctite brand sealant that’s a thick, black RTV. Turns out everyone uses the permatex right stuff. Pretty sure I could run it without the case bolts after that stuff cures.
Oh yeah! Then kick that bish to the curb right quick before she *s-words the bed on ya. lolAll kidding aside, I'd do some weird shìt with Amber Heard. Why not..
That's why we keep you around...All from Japan and with "bond" in the name, gives the clue as to the maker.
