Simondo
Two ways to do the same thing...to mount a coil (ignition module) next to a flywheel to give a spark.
But ...maybe there are other things to take from the designers choices to do with location and to aid the case shape .
The pics show 2 common locations of the 1 piece unit of (many Husq at oil tank end of the case but mostly enclosed) ..saws or many other OPE motors.
I believe we will agree that electronic components need to have some cooling, so do we think ether choice ...may ... have a down or a up ?..for performance and longevity of a coil ?
The red one is somewhat more in the open and the cross saw air flow, where as the black one is having more of a direct blow from the fan off the flywheel as it sits in part of a slight "snail back shape" enclosure.
The red one "possibly" could get more heat soaked after stopping the saw unless you allow a idle to cool things a little where as the black one could be looked upon as more "Heat Shielded " from the cylinder and muffler ..BUT.. can get covered in crap that stays put thus stopping the best cooling from the fan.
Cooling and not allowing heat soaking of a motor is paramount ....and so i would say it is the same for the electronics involved.
What say you ........
