The after.. looks good. I'm curious about the build.... squish, base gasket, psi(before & after) Timing advance....that sort of thing.Before and after videos?
And do I get a Moob's famous sticker?
slacker
I'm gonna tell Glenda that you're mistreating me again.
ill tell her you called her maam
Randy, Dall said you charge $250 for the sticker and the rest is for a hotter plug??
Yes........you get a sticker.
remember randy the torture you say you get is really the love and respect the guys here show you
I feel you on things looking the same. I run a machine that makes cigarette paper the filter end to be precise. My job is also to look for defects in the print color so on. I get home some nights after 12 hours of looking at the same material and my wife will ask what kind did you run tonight? I'll stop and think about it a few seconds nope no idea lmao!
Will the 261 Mtronic carb still provide plenty of fuel for a strong woods port?I take .030" out of the squish. Then set the clearance at .020". Yes, it has a base gasket. Timing is advanced 5 degrees. I don't check compression much anymore......but when I was figuring these out I was aiming for 210psi at sea level.
Do you gut the stratos on these Randy?
