Terry Syd
- 7:44 PM
- Jan 18, 2016
- Comboyne, NSW Australia
Why bother? The strato may furnish fresh air, but that (air) is what you need to make more power.
With the turbulence in the cylinder and especially at TDC with the squish the cylinder charge (air, exhaust, mixture) is essentially a homogeneous mixture - it is all mixed together.
That's why a 'strato' can work, the mixture is homogeneous when it starts to burn. (you may have noticed that the stratos are making more power than older designs)
If you mix the two flows you will simply be loosing mixture out the exhaust port during the cylinder charging phase. You still have the same air in the cylinder, but some of the fuel will go out the exhaust port. In other words, you will have increased the fuel consumption without an increase in power.
