Best Buy Co, Inc. Buy Used Saws CCC Ebay Store HLSupply Daily Deals
Husqvarna 550xp pop up
Discussion in 'Chainsaws' started by WoodsliverDan, Dec 4, 2018.
  1. WoodsliverDan
    WoodsliverDan Mechanical Beaver Builder
    Jul 30, 2018
    205
    283
    25
    Michigan
    I checked squish today, @.025". So a little shy of my .020" goal. That's ok, I'll check timing numbers today since I have to head to work now. Hopefully I'll get it started as well..
    Tor R, Poleman, Red97 and 1 other person like this.
  2. WoodsliverDan
    Jul 30, 2018
    205
    283
    25
    Michigan
    Tomorrow *
    Poleman and Red97 like this.
  3. Farmchuck
    Farmchuck Super OPE Member
    May 13, 2016
    412
    675
    178
    Nepa
    Hi guys, not trying to derail this but it sounds like a lot of 550 experience here. I have a 550xp which was ported by Randy & I love it, my only issue is that I’ve never owned a ported saw before & had no idea how LOUD they were. After running it a while I couldn’t handle the noise ( yes I do wear hearing protection) so I purchased a new factory muffler of Bob Spike60. I have had it on the saw for the last year or so, as you probably know it doesn’t run nearly as well as with Randy’s customized muffler.What I’m wondering is there an in between solution? Perhaps a way to modify the factory muffler to let the saw breath a little better but not be quite so loud. Also am I risking cooking my ported saw by running it with a factory muffler? Thanks guys.
    Czed likes this.
  4. AlfA01
    AlfA01 Powered by Olive Oil and FETA Cheese..
    Mar 8, 2018
    2,150
    12,663
    420
    Evia, Greece
    Have you had any issues with it not starting when it's hot? You can open the muffler a little bit to let some heat out without it being over the top loud.
    I've never had one of Randy's 550's so I'm not sure how he mods the mufflers. Most of these saws don't cook themselves from heat.
    The reason these saws had problems with scored pistons and cylinders were due to several factors.
    Air leaks, lean condition, too lean of fuel mix and dull chains are the usual causers of scoring. If you are running by Randy's suggestion - 40:1 Only, you shouldn't have a problem there.
    On another note. IIRC Randy drops the cylinder on those, which causes the exhaust not to fit just right. Make sure you elongated the lower bolt holes so you get a good seal at the cylinder.
    Dub11, Tor R, drf256 and 3 others like this.
  5. Farmchuck
    May 13, 2016
    412
    675
    178
    Nepa
    C261628B-B84E-4E39-BB51-53190ADB7BEA.jpeg CEE0E250-323A-40BF-8427-9B8DB94AC478.jpeg No hot start issues. Factory muffler seems to fit fine with existing bolt holes. Can you explain in a bit more detail about the muffler modification you speak of? I’ve never attempted to modify a muffler before & I’d hate to mess it up.Here are a few pictures of the modified muffler.
    AlfA01 likes this.
  6. Farmchuck
    May 13, 2016
    412
    675
    178
    Nepa
    Forgot to mention I do run @ 40:1 am soil saber & 90 octane e free fuel.
    AlfA01 likes this.
  7. Farmchuck
    May 13, 2016
    412
    675
    178
    Nepa
    Not that I am trying to start an oil thread here or anything but if anyone has any better suggestions I’m all ears. Seems a while back I read Randy was going to try some am soil dominator, wondering if that is better than the saber?
  8. Farmchuck
    May 13, 2016
    412
    675
    178
    Nepa
    If these questions need to get moved somewhere else I understand. Not trying to derail but since we were on the subject of 550s I figured what da heck.:)
  9. Farmchuck
    May 13, 2016
    412
    675
    178
    Nepa
    9D27B9DB-3FB7-4260-B274-8D3F9153F77D.jpeg 81047101-511C-46EC-89B2-3567A74F2EEA.jpeg Perhaps these are better photos. I do love the way the saw runs with this muffler. Much Much better than with the factory one . Just wondering if there is some middle ground.:)
  10. Backtroller
    Backtroller Pinnacle OPE Member
    2,077
    7,453
    345
    Land of Badgers
    I know what you mean about the loudness. It bothers some worse than others. These and the 562 seem to get loud with any muffler mod.
    I had a 2252 with a big 1” pipe and it ran great but using it for extended periods bothered me. I ended getting a new one and just opened it up under the factory baffle....but this was on a basically stock saw. Performance was a bit less in this situation.
    Now on a mmws I’m betting that performance is going to take a big hit without a free flowing muffler.
    Maybe foam plugs under muffs?
    Tor R, mdavlee, Red97 and 1 other person like this.
  11. Farmchuck
    May 13, 2016
    412
    675
    178
    Nepa
    That’s what I wear for protection when I run it. For me personally one or the other alone isn’t enough.
    Can you explain in more detail what you mean by”just opened it up undythe factory baffle”
    I’ve never attempted to modify a muffler before.:)
    Red97 likes this.
  12. Backtroller
    2,077
    7,453
    345
    Land of Badgers
    I cut the baffle a little on each side with a dremel and bent the baffle open. I then grinded to make the “hole” as large as the area that the baffle had covered. So I basically made it open around the “tube” under the baffle. I then folded the buffle down and welded the cuts that I had made.
  13. huskyboy
    huskyboy Sorta a Husqvarna guy.
    May 30, 2016
    4,516
    16,737
    426
    Try two 3/8 holes on either side of the one under the deflector. They get louder when you open the big internal baffle/diffuser whatever it’s called inside.
  14. Backtroller
    2,077
    7,453
    345
    Land of Badgers
    Or that
    huskyboy likes this.
  15. Backtroller
    2,077
    7,453
    345
    Land of Badgers
    That is probably the total area that I opened up. There isn’t much real-estate under the baffle since I didn’t totally cut off the baffle
  16. Farmchuck
    May 13, 2016
    412
    675
    178
    Nepa
    Is the deflector the thing that sticks up on the muffler with the screen inside?
  17. huskyboy
    May 30, 2016
    4,516
    16,737
    426
    Yes, make sure whatever you grind/drill is under the deflector. I just used pliers to lift it up to get room to work and then I tapped it back down with hammer. Make sure u get all the shavings out.
    WoodsliverDan likes this.
  18. WoodsliverDan
    Jul 30, 2018
    205
    283
    25
    Michigan
  19. WoodsliverDan
    Jul 30, 2018
    205
    283
    25
    Michigan
    Got the wheel on it tonight, came out with 106-115-78 and stratos at 79. Figured that is an ok start, so I put new ring in piston and put carb back on. Popped after 6 pulls. Haven't put a bar on it yet, and since it was about midnight, it will have to wait til later this week. So far I'm impressed with the snappiness and compression.
    Red97 likes this.
  20. Chainsaw Jim
    Chainsaw Jim #fartedinthebandwagon
    Feb 8, 2016
    3,888
    18,280
    431
    Springfield Oregon
    Stock numbers?
    Red97 likes this.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
