cus_deluxe
terms of service violator
- 9:02 PM
- Jan 3, 2016
- Michigan
Man....how did i miss this thread?
Thank you very much sir.
@Onan18Can anyone possibly explain to me how to disable the heated carb option on the XPG model? Or link a thread? Thanks.
I know nothing of G models, but I believe that you can just unplug the carb heater.
Have never seen a service bulletin regarding the subject and it will be a little "if".Can anyone possibly explain to me how to disable the heated carb option on the XPG model? Or link a thread? Thanks.
The setup on XPG:
Grounding -> Generator -> front handle -> switch -> rear handle -> grounding.
Grounding -> Generator -> top carb heather -> airfilter heather -> grounding.
As you see, the only heather system you switch on/off is the handle heathers.
The carburettor heather is working permanent.
When you disable the carb heater circuit on 550 you dont plugin the wire who head from the carburettor to the front handle switch.
Simplest thing to do is unplug the carb heater and see if the handle heat still works. Will tell you if they’re wired in series or parallel. Is the plug accessible when the carb is installed? Never had a G model.
