Husqvarna 51/55 fuel tank vent leaking.
RedFir Down
4:57 AM
Idaho
Hello fellas.
I have this Husky 55 on the bench and I can't get it to stop leaking fuel out of the tank vent.
I've replaced it with a new OEM vent with no change.
I've looked through a few of the threads but didn't find much talk about the vent being an issue.
Thanks for the help!
6:57 AM
When does it leak fuel? All the time? Or weeps slightly when refueling? (which is somewhat normal to an extent from what I have seen on the older pre-epa design tank vents).
RedFir Down
4:57 AM
Idaho
When the saw has a 1/2 tank or more and it is being moved around (Using it, in the back of the truck or side by side).
Right now I have 3/4's of a tank in it and when it on the bench I can move / rock it around for a few seconds and I notice it seeping fuel out of the tank vent.
6:57 AM
That’s not normal, and you said your positive it has every part of the tank vent in there?
RedFir Down
4:57 AM
Idaho
Yeah. The new tank vent came with the plastic tapered straw looking piece that goes into the tank and there is a small white piece of vent material that presses into the end of it.
RedFir Down
4:57 AM
Idaho
Sounds to me like the tank vent isn't seated properly.
Thanks for the reply.
I'm pretty sure its seated properly. I even cleaned everything well and put some Dirko on the stem of the vent to make sure.
When I move the saw around then shine a light at the tank vent, I can see fuel seeping / bubbling out of the vent material.
The old and new vent do the same thing.
I'm trying to come up with a reliable way to use an Echo vent or even an MS170/180 duck bill vent but I haven't found a solution.
Kenskip1
5:57 AM
Waynesville, Missouri
Well I have. Yes my 51 was leaking mix in the place you mentioned.To correct this I took the vent out of my parts warehouse.In other words my 55.Anyway with a punch I tapped the one out of the 55 then removed the leaking one from the 51. Tapped the one from the 55 into the 51. It still leaked. Then I got a bigger hammer and gently tapped it. It is now in it's place and no more leaks.
Junk Meister
5:57 AM
Nebraska
Doesn't the white disc have one side smoother than the other? ( I really had to look hard) I was told it is directional.
?? Smooth/slick side to tank?????
