Chris Zautner
- 2:17 AM
- Jan 18, 2016
- New York
Ok everyone here's a little bit of information for you all on how to trim the limiters on your chainsaw carburetor.
Here's the tools of the trade...
Now pick the saw and start taking it apart. You may or may not have to remove the airfilter but in this situation I needed to.
Now remove the rubber piece to expose the tuning screws and limiters.
Now if you can use a fine threaded Sheetrock screw to screw into the plastic tuning screws a pull them off. In this case I didn't need to I used my knife and removed the limiters and filed it smooth.
There's two limiters on this carb to remove. Remove them both put it back together, tune and go cut some wood!
