foragefarmer
70cc groupie
- 4:36 AM
- Jan 12, 2016
- Central, Va.
Try and saw the crack as one waste piece. Like Mike mentioned, it will pretty much make whatever piece it’s in split.
That crack in another good reason for never paying for wood unless it is down, del-imbed, and cut up into logs.
I tried telling one person the quality of the person felling the tree and how it hits will determine the quality of the log. Logs from trees that were topped by a tree crew generally fair worse then one dropped complete with branches because the limbs cushion the fall and prevent the trunk from absorbing the full force of the fall at 60+ MPH and bending upon impact.
imho, If you want to make sure the best part of a big log is junked, have the hinge right in the middle of the log and make sure the angle cut is below the horizontal cut.
That depends on the species of tree/timber you are felling. I have topped many of walnuts/red oak/black oak and poplar. With included bark crotches to keep the tree from splitting in half all the way down to the stump. You are correct on the person felling the tree can really mess up a money log. But limbs can help you and hurt you in production felling. But there are many variables the ground the you are laying the tree in. Humps/dips/stumps/rocks,etc can destroy logs.
