You could very carefully cut a groove into it with a Dremel from the outer edge to as close as you can to the crank lobe as you can get as deep as possible without cutting into the crank then stick chisel in the Grove and whack it. Should split down the Grove then basically slide off.
This!Put the bearing back together and use grease tospace the balls then you can use a regular puller
