- 2:18 PM
- Jun 21, 2020
- Oil Country
What’s the top of the piston look like? It looks like something got in there and was hammering the squish band. It will take out a crank in short order
Can you take a video of the “play?”
One pic has that look... I don’t know if it’s an illusion or not.
+1. That piston will tell us a lot.
Every big end bearing failure I've seen on 394 288 cranks ....the crank looks much worse than that. Usually there's pieces of cage missing...needles missing. I would like to see a video of the play too. Your bottom end looks pretty clean to me.
Upon more examination i dont believe i ever did remove the base gasket. There is no evidence of it and every time i do it, its messy. You can still see the machining marks from the factory and the gasket lettering.
anyways here is the vid
Here are some more shots of the piston top and a clearer shot of the inside top of the cylinder
