- 7:32 AM
- Jun 21, 2020
- Oil Country
Noticed when I ran this saw earlier it literally sounded like a tractor at idle... didnt think too much of it and passed it off as just big saw noise...
Few hours later I decided well ill pull the flywheel cover off and just see what i can feel spinning the flywheel. Sure enough when i lightly rotates the flywheel back and forth I could hear a clicking noise coming from inside. Made sure it wasn't the clutch bearing or something and confirmed it wasn't so i took the top end off to check out what was happening.
There was a slightly amount of play given the right rotation of the crank with the piston on, so pulling the piston off i confirmed the big end bearing has up and down play
It also is making noise when rotated, something is grinding in there...
Too bad, i was boasting about how this saw is the most reliable saw ever and this happens. Looks like the gods were not smiling down on me...
this saw was run 32:1 with maxima k2 oil for 3/4 of its life. It was my primary milling machine until i replaced it with a 3120. The other last 1/4 of its life before i retired it early this year was 40:1 with the same oil.
Inside is really clean, this saw has never been apart before from what i can remember and the intake is immaculately clean. However the scratches on the intake indicate some kind of particles got in due to the scratching. Big end shows no sign of overheating as their is no discolouration.
if you look at the photos you can see the right side of the cage has a polished look to it where you can tell it was starting to rub in the rod. The left side, nothing really.
I now have all the tools to do this job, including the seal pullers. The splitter from the 372 will work on this saw according to the part number of the tool.
if anyone has any input or ideas on failure causes please chime in.
