How to braze a deflector on a muffler
Flying_Dutchman
11:25 AM
MI
Does it matter if I get the 45% rods instead of the wire? Also how would the 5% work compared to the 15%? The only thing I've found locally so far is 5% in 1/16" rods.
Sent from my moto g(7) power using Tapatalk
Fruecrue
certified hand catcher
11:25 AM
Alden NY
There’s more mass in the rod over the wire and can act a bit sticky. Remember not to melt it with the torch. You want contact/ conduction from the base metal to melt the alloy. Once the rod warms up it flows nicely.
I’ve never used 5%.
Fifelaker
11:25 AM
N. Mi.
The brazing sure looks much easier, and looks neater. What about the strength compared to welding? Good point Randy about the screens though. I like to have them. Don't ask me why lol.
Strength is a non issue, carbide teeth on saw blades are brazed on as you can't weld carbide.
Flying_Dutchman
11:25 AM
MI
I’ve never used 5%.
Thanks for the advice! I'll order some wire and flux sometime in the next day or two.
tek9tim
8:25 AM
Winthrop, WA
I'm stuck with bolt on deflectors for the most part.....gotta have a screen.
But for the guys that are ok without a screen, brazing is so much easier.
I've done a few of these where I make an H shaped hole, drill holes into the tabs that stick out (easier before you hog out the material), weld a deflector on, and screw a screen on from the inside. The deflector pictured has been in service for 11 years, and I actually stick welded it. Scrounging around found some super tiny 7018. Do what you've got to when you're in the middle of nowhere central Idaho and your oxy/acetylene tanks are still over in WA.
Since I'm out west, I cut almost all of my firewood on public land where spark arrestors are required. It's automatic negligence if you start a fire without a spark arrestor, but if you start a fire and you had a spark arrestor you at least get to plead your case.
J_M____
11:25 AM
CT
For brazing stainless use Harris stay clean flux. It’s pretty nasty hydrofluoric acid, be very careful but it’s one of the only flux that will etch the stainless well
Cerberus
Cerberus the aardvark, not the hell-hound!!
11:25 AM
Florida (tampa area)
Anyone know of a good deal on "kits" for doing this? I'm only looking to do about 3.5" so buying the smallest sized containers of all necessary stuff (except torches, have plenty of butane&propane torches, deflectors etc materials but none of the brazing stuff), if I buy smallest-size I'd be better off just paying someone to weld it, it seems... IE I'd spend an afternoon and well over $50 (at least) to (hopefully) end up with my 3.5" weld/braze and a whole bunch of extra brazing supplies that'd be stored-away :p
Love the idea and have a muffler I'm doing right now that'd really benefit but once i priced out everything it once again "looks more practical to just post a "$50 to someone who can do a 3" weld for me" advert on facebook" situation (and, if there, I'll just stick w/ the nuts&bolts, they're ugly but I can't justify $50 for aesthetics of my muffler!)
Cerberus
11:25 AM
Dave....have you tried that on a stainless steel muffler.....like an MS261?
Wow that would be HUGE to know, what materials are OK/NOT! I'd be looking to do this on my steel 660 muffler (think it's steel, maybe "pig iron" lol I don't know but it's ferrous/magnetic and heavy!), and on my 2511t stainless muffler I need to affix a "plate" (to block-off a hole entirely) so I expect it'd need to hold stronger in that case IE more pressure on it...though I guess I can just do a ton of overlap, if it is a worthwhile-expense for just 2 deflectors!
Ronie
11:25 AM
NC
I got my stuff from Amazon, the MAPP gas I got locally.
Screenshot from 2022-04-17 11-27-51.png Screenshot from 2022-04-17 11-27-13.png
Ronie
11:25 AM
NC
I used it on a stainless pill grinder handle a few months ago.
11:25 AM
Ronie
11:25 AM
NC
Same thing I use on stainless. Make sure it’s clean by sanding all the surfaces. For carbon steel I use bronze brazing rod because of the cost.
Can you use the bronze brazing rods with MAP, I got rid of my cutting torch and tanks years ago because I never used them and they were just taking up space.
11:25 AM
If you use the smaller rods, yes. 1/16”. But it takes quite a while to get it hot enough to melt the bronze, so it may be a better trade off using silver solder vs using up your Mapp gas I guess. With acetylene torches it melts almost instantly
Woodpecker
Sassy Madam
11:25 AM
Some of the hvac guys are starting to move toward oxy/mapp torches for brazing linesets. Should be able to get a torch for around 75 bucks and of course the mapp and oxy tanks are sold just about everywhere. Oxy/mapp will get you to about 5k degrees. Moar gooder than just Mapp alone.
when I took hvac classes we learned with both a traditional torch and Oxy/mapp. We had to be able to braze a hole closed in a pop can so it was water tight to pass the final exam.
Basher
12:25 PM
Canada
I do a good bit of copper plumbing and own several B tanks, they work very well for silver solder.
