Gents,
I have a Honda powered Zanardi HM1 200 amp generator / welder. I removed the end cover from the alternator for cleaning and found this, anyone have an idea what it is?
Yes I was going to say rocker switch contact, maybe not a rocker switch, but definitely switch related.
I had a problem with my little welder, it would only work on the 2nd power setting and the min/max switch worked. but not the first power setting or third power setting.
I took the power switch off and apart , and there were a few of those things in there.
I put it back together and it all worked as it should. I was happy and relieved
edit, the only pic I took was this. The outside of the switch
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
