BigRed96
- 6:04 PM
- May 22, 2016
- New Richmond, Oh.
I have a co-workers Stihl 038 AV that I replaced the fuel line, fuel filter, impulse, and sparkplug on using all Stihl parts but the plug. I also disassembled and ultrasonic cleaned the Tillitson carb on the saw. I then rebuilt using a carb kit from Stihl. I fueled the saw with fresh fuel and pulled the starter on choke till it popped. Moved the lever up one position to fast idle and pulled, and pulled, and pulled. Nothing. Put it back on choke, no pop. Look at the muffler and gas is coming out. I flooded it. Pulled the plug and blew out the gas and let the saw sit. Tried starting again and no pop or nothing on choke or high idle. Pulled plug again, blew out gas, pulled muffler to inspect piston, piston has some light scratching on one side. Saw blows 140 psi of compression. Check spark arrestor screen and it is clear. Pulled the carb to see if I put something in wrong, all looks good. Checked spark using tool and looks good. Reassemble everything and put the saw on choke, pops on the first pull. Go to fast idle and pops again, pull again and the same pop. Pull, pull, pull. What am I over looking? I didn't replace the needle valve, spring, and lever and didn't tweak the lever while the carb was apart. Please help before I pull my hair out.
