junkman
Crush it
- 6:44 AM
- Jan 3, 2016
- pacific northwest
Wonder what would pack some dry ice around the filter ?
Iam with you Mike I like the thin ones, don't go much on the large onesI like the ones on the side of the 661 cover best. I may have to get some that size.
Are the above frogskins available for purchase yet and if so how do I go about purchasing themThe shapes they sent me, were for testing. They are NOT in production...you can't order them.
The next step is to come up with dimensions that work with a great number of saws.
So open up the PDF file below and print it out. Then cut those shapes out and put them up against various saws and report if they would work or not and what model saw.
Bottom line - we need to come up with an agreed upon oval/rectangle dimensions. ie. There needs to be enough demand, so it's worth there time to put a new size into production.
Group buy?Are the above frogskins available for purchase yet and if so how do I go about purchasing them
I'm going to raise this thread from the dead. Who is using them still? What do your filters look like after a tank? How are they holding up? Considering tossing some into my 576 and maybe blocking off the air injection.
My only reasoning for doing it on the husky would be to reduce carb heat soak by using more direct outside air as opposed to hot flywheel air. More colderer for moar better.Air injection works pretty well in my experience, in fact in theory it reduces the vacuum in the carb box and filtration has been good.
Are you having issues? I have not seen a 576 personally.
You could try it, worse case is you need to buy a new cover if it doesn't work.My only reasoning for doing it on the husky would be to reduce carb heat soak by using more direct outside air as opposed to hot flywheel air. More colderer for moar better.
