BuckthornBonnie
- 12:40 AM
- Aug 22, 2016
- Penn Yan, NY
Yep. I never build up a questionable bottom end. He got bad advice lol.Thorough inspection saves a lot of heartache my friend, lesson learned. Snag some parts from some of our illustrious members here and put some good oem parts on the Ole girl. @Miller Mod Saws
If it was me I would contact Mr miller for the bearings and perhaps a ported top end and new piston. It will really rip after that, Carl knows his way around a Dolmar.Yep. I never build up a questionable bottom end. He got bad advice lol.
Poor plating quality? Dirt ingestion?[QUOTE = "BuckthornBonnie, post: 517151, member: 1725"] Y-
[Adjuntar] 90418 [/ ATTACH]
[INCLUIR] 90419 [/ ATTACH]
Anillos Caber, mejora de filtro HD.
No construí esta sierra, pero sí proveí el kit de Weedeaterman ... Me gustó la apariencia de eso.
Aquí está el pateador - mi amigo nunca me dijo que él notó el juego de manivela. Le preguntó a un mecánico local que dijo que probablemente estaba bien. Lección aprendida; sólo construir una sierra en un buen extremo inferior. Finalmente fallará si no lo hace. [/ QUOTE]
I've seen that in more cylinders, I do not think it's a crank problem
We are thinking of parting it out.If it was me I would contact Mr miller for the bearings and perhaps a ported top end and new piston. It will really rip after that, Carl knows his way around a Dolmar.
Whaaaaat?!We are thinking of parting it out.
Haha, I know...I know. It's a 6400 that needs a crank, bearings, gasket/seals, p/c, etc. The case threads are suspect as well.Whaaaaat?!
I can't like this lolHaha, I know...I know. It's a 6400 that needs a crank, bearings, gasket/seals, p/c, etc. The case threads are suspect as well.
I'm a Stihl guy... if it were a different model then I'd probably do it up.
Haha, it's sacrilege.., I know.I can't like this lol
Never! LolLol back off Sondre!
Ahh... Good question and I thought the same thing at first.F-Cast rings?
I think F-Cast rings now come standard on most pistons.Ahh... Good question and I thought the same thing at first.
As far as I know it was a regular Caber ring. It made decent compression but nothing great. I ran this saw a few times--/ it was "ok" and comparable to an 044/440 (despite being 85ish cc).
Think they're too hard for weaker plating?I think F-Cast rings now come standard on most pistons.
