FergusonTO35
- 4:00 AM
- Jul 9, 2017
- Boonesborough, KY
That o-ring is a cheap and easy fix. Maybe try it before you call it totaled?
All I know on misfires recently has been two srm225 Echos that the rings were max end gap and the cylinder plating worn through plus the piston minimum OD was below minimum spec. They ran fine at idle but miss fires at full throttle. Wasn't a coil as I had a coils from two other srm225 that had other problems from being left out in the rain. Just too piston wobble at full throttle. Just too costly to rebuild as Echo only offer short block for these when it get to the cylinder replacement.Rings and cylinder look fine, from what I can see looking in both ports and looking up from the crank case. Its got plenty of power in between the misfires. If the oring doesnt fix it I'm just going to assume the crankshaft is bent or the flywheel hole is off center and thats causing a speed wobble that makes the magnet go far way from the coil only at high rpms.
And I have seen coils to do crazy timing of ignition at time as I had Homelite chainsaw that set the air filter on fire at times.
