CLEARCUT meets the 500i
CLEARCUT
5:23 AM
Oregon
Could you guys care to explain?
He put a rubber bushing in the spot where the foam piece is on the bottom of the saw. It strengthened it quite a bit, however it did vibrate a little more. The rubber bushing that contact the sides of the gas tank are really flimsy and weak. We thought that the 462 bushings might fit, but haven’t tried.
~WBF
Thecallofthewildanswered1989-2017[PAID IN FULL!]
1:23 PM
Uk
Europe-burb
The Faller that those amateurs @ Foesetry.com had tested the 572,462 &500 said the 462 was small for a 20" bar and the 500 was just about right???
8:23 AM
Because there trying to copy Husqvarna. Just saying.
A 372 has stronger and more durable av than a 441. 390xp stronger yet. 441 is better after fitted with the west coast springs, less sloppy and still very smooth. Should be standard equipment.
MG porting
5:23 AM
Wa
A 372 has stronger and more durable av than a 441. 390xp stronger yet. 441 is much better after fitted with the west coast springs, less sloppy and still very smooth. Should be standard equipment.
What I don't get is why didn't they use the springs in the first place they try so hard to be different but yet they try to use similar design.lol
mdavlee
Hillbilly grinder
8:23 AM
TN
I’ve heard of guys changing the foam front AV once a month on 661 to keep it from being so sloppy. They did a bad job copying husky for AV on all these saws so far that I’ve picked up.
rogue60
10:23 PM
AU
Or just pump the sloppy springs full of Sikaflex job done! ya now have half decent rubber AV mounts...
mdavlee
Hillbilly grinder
8:23 AM
TN
I used some of the AV plugs and put it in the longer to give the pin less travel. New springs and foam all around d made it much better. I couldn’t get used to it flopping around to make felling cuts after using Huskies and a 460 for years.
MG porting
5:23 AM
Wa
Stihl should have just stuck with the Av mounts of the 1980s dam Saw's didn't vibrate that bad so I can't believe that the newer Saw's would be any different.
