Redfin
Meh...
- 3:11 AM
- Dec 24, 2015
- Central Pa
Wont be using fingers if I use another 288 piston in one of these.So will I!
Please explain. Im curious on the reasoningNext set I use will be opened after the trans. Got a little eye opener with this 661 jug.
I'm not understanding this.I don't use fingers or bridges anymore.
This 660 has none.
The last few I've done made 0 difference.I'm not understanding this.
If fingers can improve bad uppers, why can't they improve great uppers?
Fingers in a quad port????I'm not understanding this.
My company shall be called:I think fingers are pointless in a work saw with stock carb also. Now a racer or play saw is a different matter..........
I like my transfer progressive lately alsoView attachment 17340
In my 661, the mains open 3* on taper before the secondaries. This saw stock was 100/120/80. It by far was the best stock saw i have ever run.
Not on a quad. No way to feed them, or I'd try to make a sex saw.Fingers in a quad port????
Go on lol
Sent from my non internal combustion device.
They look real shiney and clean for stockI believe Johns pic is of stock 661 transfers.
Main and secondary open on the intake side first?Mine open together, but are still tapered
Ya I believe they r progressive from factory?I believe Johns pic is of stock 661 transfers.
Okay i see. One toward the ex and one toward the intake.They start at the outers and taper towards the innersView attachment 17341
I like that sidewall angle and corner u have on the intake side transfer. Great aim!!They start at the outers and taper towards the innersView attachment 17341
