Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 8:11 PM
- Dec 30, 2015
- Provencal, Louisiana
What burr do u use Kevin for that corner?
A real small tapered one .......... The point does the corner workWhat burr do u use Kevin for that corner?
U have got it tight!! Looks greatA real small tapered one .......... The point does the corner work
Thank you Sir !!!U have got it tight!! Looks great
I'd have to agreeU have got it tight!! Looks great
288 is 40mm and 660 is 34mm wideOK, I got some stupid questions, so humor me:
1) If the Meteor 460 piston has wider skirts than an OEM 460, does the Meteor 288 piston also have wider skirts??? (I believe this is what Jason used)
2) Would a 460 ported to the wider skirt Meteor piston actually be stronger???
Does anyone know, and will anyone say????
OEM & Meteor are the same??? The 288 skirt is also longer, right?
AgreedMaybe I'm thinking off to but if ya didn't half to take so much off the base wouldn't that add case volume?
But..... Does the big bore actually add case volume?If the circle crank wants case capacity, perhaps a 56mm big bore P&C will be the ticket.
maybe this is the big bores calling?
It would have to .............. a wider bore will add space, both over and under the piston for the entire boreBut..... Does the big bore actually add case volume?
Did you put the oz 660 oiler in your saw or was it modifiedBefore Keith G. modified my 660's oiler, it didn't lube my 28" ES bar well. The bar was getting so hot, especially when cutting stumps, paint was coming off the bar. After the oiler mod, it runs a lot cooler.
Looking forward to that threadThe new GB bar I bought had the same little angled hole as the Oregon bars do I drilled it out as well
Oiler at max, that's about 3o seconds at WOT and a 10 second video of the red light operating which I will post up in the 066 red light thread soon
LMAOOh, and I almost forgot, does a meteor 440 piston have wider skirts than a OEM 440???
Damn, I'm full of skirt questions tonight, and all you guys just focusing on the breasts!!!
