Socalmisfit
- 1:09 AM
- Nov 19, 2020
- California hi desert
So I have a tecomech grinder but the 10 degree offset is on the side not the swivel base. So you adjust forward or back for right and left teeth. Was wondering if anyone has tested both types and which you liked better. I feel like with the offset forward and back the teeth are different. I haven’t used a swivel base type yet. Seems like recently cuts have been off to one side or the other. I set rakers with a progressive gauge so each tooth is set to itself. And the chain adjustment on the saw is right also. Not sure how often everyone changes their bars, but I put them on a flat surface and their seems to be no bend. A little play in the bar guide but nothing real crazy. Might just be the chain is wore out, they are at their last grind. Thanks guys.
