P.M.P.
Stiff Member
- 10:36 AM
- Dec 31, 2015
- Michigan
http://www.makitatools.com/en-us/Modules/Tools/ChainSaws/
MAKITA AND DOLMAR ARE MERGING INTO A SINGLE BRAND: MAKITA POWER EQUIPMENT.
Under the Makita brand, this integration gives users a full range of professional chain saws for forestry, farm, and occasional use. Professionals and occasional users will benefit from a deep line-up of power equipment that also includes Makita MM4® 4-stroke engine products and over 125 18V LXT® and 18V X2 LXT® (36V) Lithium-Ion cordless solutions.
EASY START
Spring-assisted starter combined with low RPM ignition coil for easier starts.
Single choke/run/stop lever with simple shut-off stops saw with just a touch.
TOP PERFORMANCE, HIGH POWER-TO-WEIGHT RATIO
MODELS
EASY START
- 30% less pull resistance
- Smoother more dependable starts
- Less wear to starter assembly
- Convenient single choke/run/stop lever
- Stops saw quickly with just a touch
- Lock-off position to prevent starting
- Magnesium housing for improved durability and less weight
- Die cast cylinder with closed transfer ports improves fuel exchange for more power
- Optional heavy-duty cartridge air filter system for extended air filter life and improved durability
- Optional full-wrap and heated handle for greater versatiliy
- Floating rim sprocket for easy maintenance and improved chain life
- Easy Start spring-assisted starter combined with a low-RPM ignition coil significantly reduces pull-starting force for easier stars
- Touch & Stop single lever control shuts off engine with just a touch
- Easy filter access for convenient maintenance
- Two bar studs and side access chain tensioning for easy adjustment
- 13,800 RPM with fast acceleration for more efficient cutting performance
- Slide-out-baffle for efficient cold or hot weather operation
- Optional heated handle for improved user comfort in cold weather climates
- Easy Start spring-assisted starter combined with a low-spark ignition coil significantly reduces pull-starting force for easier starts
- "Tool-less" chain tensioning for quick and convenient chain adjustment
- Optional “tool-less" chain tensioning for quick and convenient chain adjustment
- Compact design with less weight
- Two point durable inertia/mechanical chain brake
- Steel spring vibration mounts engineered to reduce vibration
MODELS
EA5000PR – 16"-20" 50 cc Chain Saw
EA5001PR – 16"-20" 50 cc Heated Handle Chain Saw
EA6100PR – 20" 61 cc Chain Saw
EA7300PR – 73 cc Chain Saw
EA7301PR – 73 cc Heated Handle Chain Saw
EA7900PR – 79 cc Chain Saw
EA7901PR – 79 cc Heated Handle Chain Saw
EA4300FR – 16" 43 cc Chain Saw
DCS5121R – 18" 50 cc Chain Saw
EA5600FR – 16"-20" 56 cc Chain Saw
EA3200SR – 14" 32 cc Chain Saw
EA3201SR – 14" 32 cc Chain Saw w/ Tool-less Tensioner
EA3500SR – 16" 35 cc Chain Saw
EA3601SR – 16" 36 cc Chain Saw w/ Tool-less Tensioner
