Terry Syd
- 11:53 AM
- Jan 18, 2016
- Comboyne, NSW Australia
because with the HD 17 it idles perfect any thoughts?
Well mate, you may have to pull those damn welch plugs and do a comparison to the HD-17. It could be that the AM carb needs a bit more air bleed in the idle circuit.
Tuning a Zama twin jet is a piece of cake compared to these type of carbs. On the Zama the low speed needle ONLY adjusts the idle mixture. The two jets control the low speed circuit flow (so it is real easy to drill them to adjust) and you just have to tweak the metering spring with a shim or two to get great throttle response. - You can tune each function SEPARATELY!
With the Walbro type circuit the low speed needle changes all THREE functions at the same time. It changes the idle, the transition and the low speed circuit flow. It is a pain to try and get all three functions correct when they are all being changed - "heck, all I wanted to do was set the idle"
It may be that the HD-17 will have the answer you're looking for under that welch plug.
