Terry Syd
- 12:00 AM
- Jan 18, 2016
- Comboyne, NSW Australia
Now when I open the hole up more I'm guessing those two holes are still putting out fuel at full throttle as well as the main nozzle?
Definitely, those bigger holes in the air bleed/transition holes will allow more air to go through the idle circuit when idling. Therefore, you must open up the low speed needle to compensate so that you get a proper air/fuel mixture at idle.
That means that the low speed circuit is now delivering more fuel when the saw is running at WOT (and thus you need to lean out the high speed needle a bit)
It also means that the low speed circuit is running richer when the revs drop, which usually results in more low end torque.
The factories want to decrease hydrocarbon emissions at lower revs when there is more time for the mixture to escape through the exhaust port. By running the mixture on the 'lean' side of the curve, they can get away with the EPA emission requirements. If you bump up the fuel flow in the low speed circuit, you can increase the low speed torque, but you will also increase the hydrocarbon emissions. - It is a matter for you which way you want to go...
