skylogger
Hey guys I got a new 661 it runs perfect but has a small leak around exhaust, I took the muffler off and back on made sure everything was snug but no change. I'm no pro but figured it doesn't matter what say you?
What are you seeing that needs welding?
That would be obvious unless you're just trying to point out that it is only leaking from between the heat shield and muffler like I obviously may not have noticed when viewing it on my small phone instead of a large computer monitor after correcting the angle for optimum viewing pleasure.What are you seeing that needs welding?
Sorry about that crooked pic i did it on my phone and thats how it came out it gets on my nerves too!That would be obvious unless you're just trying to point out that it is only leaking from between the heat shield and muffler like I obviously may not have noticed when viewing it on my small phone instead of a large computer monitor after correcting the angle for optimum viewing pleasure.
Looks like it could be runnin a tad on the lean side. Do you know what coil you have?Here's a better pic of it.
Ok, the piss rev explosion might explain it. LolThanks for the tips guys I figured it wouldn't effect how the saw ran, as for running lean it has the 4701A coil and runs really rich right now i only have 7 or 8 tanks trough it. The second pic i posted was after the first tank, i noticed the leak when the guy handed it to me at the dealership after he piss rived it to the point of near explosion
Definitely a must do.Whenever I build a saw I always take a wide mill bastard file and mill the exhaust port mating surface. You'd be shocked to see how un-flat (is that a word?) they are from the factory. Every single one that I've seen was at least a few thou if not 20 from being perfect.
That's your problem.
So unless you want to remove the cylinder.....I wouldn't worry about it. It is what it is.
EDIT: the mating surface of the muffler itself is also usually an issue. That too, gets hit with a file.
I burnt up the muffler gasket on my PS-7900 recently.Check the muffler bolt torque too. If the gasket isn't eat up it should seal.
