440 hybrid
Ronie
3:38 PM
NC
Not really a build thread, just going to post the progress on my build.
So far I've painted the cases and dyed the ugly plastics black. Put the crank in, repainted the front of the case because the oven heat gave the gray a yellow tent. Did the muffler mod and fitted the cylinder to the case.
Ronie
3:38 PM
NC
I've also started on the cylinder and cut .025 from the band and .020 off the base, squish is .022. My plan is to leave the exhaust low and more blow down than most do to start with and If I don't like it I'll go back in and change it, looking for good torque. The pic of the port timing is after I cut the base and how I want it to end up.
Just want to add that's it's a Stihl branded jug.
Bjorn
12:38 PM
Sweden
Hello. Are you going to use the original piston, or a 272 piston? The 272 piston is higher and singel ring. Very nice for making a pop up piston.
Ronie
3:38 PM
NC
I'm going to use a 440 piston, I cut .025 from the band. I would have cut more but I don't want the compression to high. My right elbow and shoulder are shot and I starting saws with my left arm at the moment.
Bjorn
12:38 PM
Sweden
Decomp? 440 piston?
Ronie
3:38 PM
NC
I've been doing some thinking about the transfers and had decided to angle them so that the exhaust side opens first instead of the intake side like it came from the factory. I figured I'd cut them flat and then mark a couple of degrees higher, then cut from the intake side up to the mark on the exhaust side. After cutting them flat, I thought that they are starting to get big and I didn't want them any bigger than they need to be so I'm just going to leave them flat.
I also was looking at how flat the exhaust roof is a put and larger bevel on it.
New numbers are,
EX 104
TR 124
IN 78
Ronie
3:38 PM
NC
I took .025 of the flywheel key and got the cylinder on this afternoon, it free ports a little, maybe .010, but I think it will ok with that. I didn't take any off the floor so it must have been close to start with.
Wonkydonkey
Plastic member
8:38 PM
Sussex, UK.
Although it probably wont matter with that little bit of free porting if you need a bit more squish clearance, a little gasket made from a soda can or something would sort both out ;)
Ronie
3:38 PM
NC
I'm going to leave it and see how it does, squish is .022 so I'm good there.
Ronie
3:38 PM
NC
Didn't get much done today , I put the seals in and vac tested it, opened up the hole and extended the deflector on the back half of the muffler, I'm out of flat black so I put some gloss on it.
Ronie
3:38 PM
NC
I picked up some VHT header paint so I stripped that gloss paint off the muffler and repainted it this morning. I also drilled a few holes in the outside spike and painted both spikes, tomorrow I'll put it in the oven and bake the muffler and spikes.
