- 2:22 PM
- Feb 5, 2016
- grafton wv
i think a 460 came in that box lol hopefully you took the piston out of the box also
lmao im glad i kinda blew the saw off when i put it away a couple months ago
you better start rubbing her feetMe too. She's pretty understanding.....but there is a line. lol
For Dallas to ship an 088 would require a washing machine box. I've seen it.I stuffed an 088 in that box.
a nozzle check not sealing good will cause that. a run through ultra sonic cleaner fix it
So what is the correct metering height, flat to the carb body as on all walbro's? started on a full tear down of my 372 the other day, new crank seals, new o-ring between collar and bearing and fresh carb kit. Mine would idle down slowly after cutting though 20"ish hard wood and then be very sporadic and weird on the idle. Tuned the idle again, set the screws to 1 and 1/4 each and start again.. And even tried to richen up the L needle. Same would happen in any scenario. Ill see if all the seals and carb kit fix the issue.These things are almost always either tune, or metering height Gary. Double check metering height.......and start over with carb setting at 1.25 turns out on both screws.
