Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 5:10 AM
- Dec 30, 2015
- Provencal, Louisiana
That 357 looks more compatiable to the 372 than the 550. Did ur bottom inner bolt up? I added a 2nd screw on the outer dawg for securityGood idea Keith. I had my 372XT doubles laying around after I put the large set on it so I fitted them to my 357xp. I did all of the fitting with files, it didn't take too long, about an hour. I think it turned out pretty nice. I think the size of these dogs is a perfect fit for these smaller saws.
View attachment 14199 View attachment 14200 View attachment 14201
if you have welderFirst I mount the inner dawg with the top screw because the bottom wont mount. Next step I took a washer and shape until the bottom sit where I wanted it to and the bottom butted against the washer and not the crankcase. I may have to weld that washer to the dawg??? Next if u will notice I ground the bottom of the inner dog until that ole husky set flat and didnt wobble side to side like they r known for!!! View attachment 14189
if you have welderNext came the outside which was an obstacle!! !! I had to cut the back mounting hole off in order to adjust the front where it needed to be. The top mounting hole had to be ground out almost to the top and the very bottom of the dawg had to be ground to lower it down also. Finally getting the dog to set lined up with the inside dawg I had previously drilled a new mounting hole for the set screw and held it in place and drilled a pilot hole in the clutch cover. I then took a sheet metal screw and mount the dawg to the clutch cover. The back self retaing bar nut stud mounted right up but the front nut springs didnt line up so alil more notching with the foredom on the dawg until the retaing spring of bar nut fit through the dawg!!! And presto!! Double dawgs on a 550 and this dang husky dont wobble side to side any more!!!!View attachment 14190
Keep putting them stihl parts on there and one day you will have something.Added a Stihl side to side chain roller for a more rigid mount. I think this will workView attachment 14264View attachment 14265
I've gotta ask...WTH happened to your sticker?Added a Stihl side to side chain roller for a more rigid mount. I think this will workView attachment 14264View attachment 14265
That 357 looks more compatiable to the 372 than the 550. Did ur bottom inner bolt up? I added a 2nd screw on the outer dawg for securityView attachment 14216View attachment 14222
