365 carb
MinnesotaJon
11:38 AM
Grasston
I found a metal replacement for the white plastic one. Is that an OE fix or is that just a Chinese part.
old guy
Love me some Husqvarna
11:38 AM
Becker Minnesota
I found a super clean 365 it had the zama carb on it. It wouldn’t run googled the carb saw they were not the best. Saw they had new model zama to replace the old. It was only 20 so I wasn’t to confident. Still don’t run can get it to idle but bogs with throttle. Hold pressure and vac so what carb should I get to replace it. Pretty sure the HD12 is the one just wanted to double check. I am getting a timing wheel and am going to try and port it if that makes any difference. I have a 372 some one did some work on that has the 390 carb on it. But I don’t think this thing will need that.
Jon I still have the HD12 that came off that 372 if you wanna come get.
Woodslasher
Teh debil
9:38 AM
Commiefornia
It’s a Chinese part, but it might be the one Chinese part that’s better than oem
I put one of those on my W for that exact reason. It has a little casting flash but overall I like it. The saw doesn't sound like it's developed an air leak since I swapped it over, so I'm gonna say it's pretty good quality.
