346xp question...
Roscopico
6:00 AM
Ontario
Hello. I just acquired this saw. Was looking it over and have some questions. I do not believe if has original piston and cylinder. Seems to be a 2010 model. There is no decomp. Here are some pics. Any ideas?IMG_20180304_132521.jpg IMG_20180303_192256.jpg
decableguy2000
6:00 AM
WNC
I think it is an OEM cylinder, but an OE 42mm. I'm not sure of the switch, but I think it was when they added the primers as well
Roscopico
6:00 AM
Ontario
My thought was that it was an OEM cylinder as well. Just not sure from what.
Roscopico
6:00 AM
Ontario
I just did a compression test. Only 135 psi. But it runs and cuts real nice
sunfish
5:00 AM
Success Mo
It's an oem 346xp cylinder, but the older version. 135 psi isn't good, if your gauge is right, should be around 160. New oem 50cc top end is $120 if you want, or a Meteor piston for that cylinder $35 or so. Pull the muffler and have a look at the piston. Very good saw and well worth throwing a little $ at!!!
Roscopico
6:00 AM
Ontario
Okay thanks Sunfish. I think I will go with the new 50cc oem p&c. I will bet they cost a lot more here in Ontario Canada though.
Roscopico
6:00 AM
Ontario
Cuts real strong. Only put it through a few cuts in back yard though. Will give it a good run and will see.
CJ Brown
6:00 AM
Belleville, Ontario, Canada
Rather than start a new thread I thought I would tack onto this one. I have a tree service guy asking me for a 346xp but they are a rare bird in this area. I do have a nice 351 that I can convert so I have looked up the oem kit for the 346ne. What I noticed was the 346 and the 353 kits have the same oem part number. Has it always been this way? Does that mean that any 353 rebuilt today will become a 346xp? Also, will the converted 351 suffer if I use the oem 351 carburetor?
cuinrearview
Unskilled Hammer Donkey
6:00 AM
Dowling, MI
They should not have the same part number. Hopefully you don't wind up with the 45mm jug. The 351 should have an HDA-159(here in the states at least) which will fuel a stock or lightly modded 44.3 346 just fine.
CJ Brown
6:00 AM
Okay I found where I was going wrong. When I go to Firedog and search the IPLs for the piston/cyl kit for the 353, it lists 2 different kits - 1 with decomp and 1 without, both for the 346xp 50cc. Then when I looked carefully at the parts menu, there is an "unknown" part for a little higher price, and that is the part number for the true 353 cylinder. So Firedog has defaulted their 353 listings to the 346xp kits - likely because they are cheaper and more sought after.
Here is what I get:
537253104 = 353 oem
544142907 = 346XPne no decomp
544142908 = 346XPne with decomp
I went to the Husqvarna website and could only find IPLs for the 346 - all they have for the 353 is op. manuals unless I searched wrong.
