Avisagio
- 1:11 AM
- Jan 1, 2020
- Cazadero, ca
Hi folks. Been working on a 268xp for @Normzilla. I've tried three carburetors now, one aftermarket brand new, 2 good used. Idle will fall with the clutch side up and will rev higher with the flywheel side up. This saw has a new case gasket and seals. In fact it's on its second round of seals because of the symptoms it was having. I figured I damaged the flywheel side seal the first go around so I took them out and very carefully installed another set.
Back to the carbs. I've vac'd and pressure tested and the only leak I had was at both sides of the throttle shaft. I tried o-rings but it didn't seem to help. Anyone have any specific air leak issues with this series saw? I'd appreciate any input.
Thanks, Travis
Thanks, Travis
